Ignition Control Module: Description and Operation
Ignition Components:
The transistorized ignition module relays spark control signals from the Powertrain Control Module (PCM) to the ignition coil. It controls current through coil primary windings.
The Ignition Control Module (ICM) receives a signal from the PCM, and opens and closes the ignition coil primary circuit to fire the spark plugs.
