Required Tools and Equipment
The following equipment is required to diagnose and repair the Electronic Engine Control (EEC-IV) system:Self Test Automatic Readout (STAR) Tester:
Self Test Automatic Readout (STAR) Tester (Rotunda 007-00500, or equivalent)
Jumper Wire:
Jumper Wires
Vacuum Gauge:
Vacuum Gauge (Rotunda 059-00008, or equivalent)
Tachometer:
Inductive Dwell-Tachometer-Volts Ohms Tester (Rotunda 059-00010, or equivalent)
Breakout Box:
Breakout Box (Rotunda 014-00322, or equivalent)
Vacuum Pump:
Vacuum Pump (Rotunda 021-00014, or equivalent)
Digital Volt-Ohmmeter (DVOM):
Digital Volt-Ohm Meter (DVOM) (Rotunda 014-00407, or equivalent)
