Shift Linkage: Adjustments
ADJUST1. Disconnect battery ground cable, then remove floor console.
2. Shift selector lever to Park position, then remove position indicator mount.
Sliding Back Lock Cover:
3. Slide lock cover back, then disconnect set button.
4. Slide selector lever to adjust Park position, then connect set button.
5. Slide lock cover to lock set button in place.
6. Reverse procedure to install. Torque position indicator mounting screws to 17-26 in lbs.
