Electronic Brake Control Module
Pin Number Circuit Circuit Function
1 402 (BK/Y) Right Rear Solenoid
2 404 (BL/O) Right Front Solenoid
3 51 (BK) Module Ground
4 407A (Y/W) Module Power
5 321D (W/GN) Brake ON/OFF Switch Input
6 403 (Y/GN) Left Front Solenoid
7 401 (BR) Left Rear Solenoid
8 51A (BK) Module Ground
9 40R (BK/W) Module Power
10 NOT USED
11 405C (R/Y) Motor Monitor
12 NOT USED
1 409 (O/BL) Data Link Connector (DLC)
2 NOT USED
3 NOT USED
4 NOT USED
5 412 (Y) RH Front Anti-Lock Sensor
6 411 (Y/BL) LH Front Anti-Lock Sensor
7 414 (W) LH Rear Brake Anti-Lock Sensor
8 417 (BL) RH Rear Brake Anti-Lock Sensor
9 418 (PK/BK) Data Link Connector (DLC)
10 NOT USED
11 NOT USED
12 406 (BL/O) Anti-Lock Relay (Motor Relay)
13 400 (BK/BL) Anti-Lock Relay (Fail-Safe Relay)
14 408 (PK) Anti-Lock Relay and Anti-Lock Brake Indicator
15 413 (O) RH Front Anti-Lock Sensor
16 410 (Y/GN) LH Front Anti-Lock Sensor
17 415 (R) LH Rear Brake Anti-Lock Sensor
18 416 (GN) RH Rear Brake Anti-Lock Sensor
