Rear Crankshaft Main Bearing Seal: Service and Repair
1. Remove transaxle.2. Remove flywheel.
3. Remove rear main seal housing to stiffener attaching nuts.
4. Remove six rear main seal housing to block attaching bolts, then the seal housing from the block.
5. Using seal removal tool T92C-6700-CH or equivalent, remove seal from housing.
Fig. 20, Applying Sealant To Rear Main Seal Housing:
6. Reverse procedure to install, applying a bead of silicone sealant to rear main seal housing as shown.
