1. Verify the customer concern by operating the cigar lighter.
2. Visually inspect the components of the cigar lighter system.
VISUAL INSPECTION CHART
Mechanical
- Damaged retaining fingers
Electrical
- Blown fuse:
^ 15A AUDIO
- Damaged wiring harness
- Loose or corroded connections
- Damaged element
