Brake Signal: Description and Operation
Typical Brake Pedal Position Switch:
The signal informs the Powertrain Control Module (PCM) to disengage the torque converter clutch.
On certain applications, the PCM adjusts the engine idle speed with the brakes applied and the A/C turned On, or turns the A/C Off after a calibrated time.
The Brake On/Off Switch (BOO) signals the PCM with a battery voltage (B+) signal whenever the vehicle brakes are applied.
If all the stoplamp bulbs are burned out (open), a high voltage is present at the PCM due to a pull-up resistor in the PCM. This provides fail safe operation in the event the circuit to the BOO switch has failed.
