Oxygen Sensor: Service and Repair
NOTE: This procedure applies to both the upstream and downstream Heated Oxygen Sensors (HO2S).
3. Disconnect the HO2S electrical connector.
Downstream Shown, Upstream Similar:
4. Use Oxygen Sensor Wrench T94P-9472-A to remove the HO2S from the exhaust inlet pipe.
2. Tighten the HO2S to 30-49 Nm (22-36 ft lb).
