Freeze Frame Data
Freeze Frame Data Table:
DESCRIPTION
Freeze Frame Data allows access to emission related values from specific generic PIDs. These values are stored the instant an emission related DTC is stored in Continuous Memory. This provides a snapshot of the conditions that were present when the DTC was stored. Once one set of freeze frame data is stored, this data will remain in memory even if another emission related DTC is stored, with the exception of Misfire or Fuel System DTCs. Once freeze frame data for Misfire or Fuel System DTC is stored, it will overwrite any previous data and freeze frame will not be further overwritten. When a DTC associated with the freeze frame is erased or a PCM memory reset is performed, new freeze frame data can be stored again. In the event of multiple emission related DTCs in memory, always note the DTC for the freeze frame data.
PROCEDURE
- Perform the necessary vehicle preparation and visual inspection.
- Connect scan tool to Data Link Connector (DLC).
- Select NEW VEHICLE YEAR & MODEL.
- Select VEHICLE & ENGINE SELECTION menu (OPTIONAL).
- Select year, engine, model with the appropriate qualifier, if needed (i.e., transmission, 49 States, California) (OPTIONAL).
- Follow operating instructions from the menu.
- Select GENERIC OBD II FUNCTIONS.
- Press CONT button if all OBD II monitors are not complete.
- Turn key ON.
- Select FREEZE FRAME PID REQUEST
