Positive Crankcase Ventilation Valve: Testing and Inspection
NOTE: Perform this inspection while the engine is cold.1. Run the engine at idle.
2. Disconnect the Positive Crankcase Ventilation Valve (PCV valve) along with the oil separator hose from the valve cover.
PCV Valve:
3. Block the PCV valve opening.
4. Verify that the vacuum is felt.
5. Turn the engine OFF and remove the PCV valve from the oil separator hose.
6. Inspect for and clean any dirt or other deposits from the PCV valve.
PCV Valve:
7. Blow through the PCV valve from port A and verify that air comes out of port B.
8. Blow through the PCV valve from port B and verify that no air comes out of port A.
9. Replace the PCV valve if results are not as specified.
