Fuel Pressure Regulator: Service and Repair
WARNING: Fuel in the fuel system remains under high pressure even when the engine is not running.1. Perform the fuel pressure release procedure. Fuel Pressure Release
WARNING: Plug the fuel tubes after removing them from the fuel injection supply manifold to prevent fuel leakage.
3. Disconnect the fuel tube from the fuel pressure regulator.
4. Disconnect the fuel pressure regulator vacuum line.
5. Remove the fuel pressure regulator bolts (2).
6. To install, reverse the removal procedure, using a new o-ring and a new fuel return hose clamp. Tighten the fuel pressure regulator bolts to 8-11 Nm (71-97 lb in).
