Vehicle Damage Warnings
CAUTION: The rubber fuel tubes can be damaged by torches, welding sparks, grinding and other operations which involve heat and high temperatures. If any service operation will be used which involves heat and high temperatures, locate all fuel system components, especially the rubber fuel tubes to be certain they will not be damaged. It is recommended that the rubber fuel tubes be removed from the vehicle if a torch or high heat producing equipment is to be used for service in the following areas:
- Exhaust or suspension components in proximity to fuel tubes.
- Floorpan under vehicle and inside the passenger compartment (LH side).
- Body rocker panel (LH side).
- Underbody frames, rails, and crossmembers (LH side).
- Dash panel; under vehicle or inside the passenger compartment (lower LH side).
- Front or rear wheel house/fender apron (LH side).
