Fuel Supply Line: Service and Repair
WARNING: Fuel supply tubes will remain pressurized for long periods of time after engine shutdown. The pressure must be relieved before servicing the fuel system.NOTE: All fuel tube clamps must be replaced with new fuel tube clamps. Do not reuse old fuel tube clamps.
1. Perform the fuel pressure release procedure. Fuel Pressure Release
2. As needed, remove the fuel tank for access to the fuel tubes to be replaced.
Fuel Supply And Return Tubes:
3. Disconnect the hose clamps at both ends of the fuel tube to be replaced.
4. To install, reverse the procedure for removal.
