Idle Speed/Throttle Actuator - Electronic: Service and Repair
1. Remove the air cleaner to intake manifold tube.
2. Remove the throttle body.
3. Remove the Idle Air Control Bypass Air (IAC BPA) valve screws.
4. Remove the IAC BPA valve.
2. Tighten the IAC BPA valve screws to 2.5-3.5 Nm (22-31 lb in).
