Throttle Cable/Linkage: Adjustments
FREE PLAY1. Verify that the throttle valve is fully closed.
2. Measure the free play at the accelerator pedal. Free play should be 1.5-4.5 mm (0.06-0.18 inch).
3. If adjustment is necessary, turn stopper (B) while pressing lock button (A) to release the lock.
4. Push the spring (C) towards lock button (A) and adjust the accelerator cable free play.
5. After the proper accelerator cable free play is achieved, lock the stopper (B), then the lock button (A).
6. Adjust the wide open throttle position.
WIDE OPEN THROTTLE POSITION
1. Adjust the accelerator pedal shaft lever free play.
2. Depress the accelerator pedal all the way to the floor.
3. Confirm that the throttle plates in the throttle body are in the wide open position.
Accelerator Stop Block:
4. If adjustment is necessary, loosen the locknut and adjust the wide open throttle position at the accelerator stop block on the accelerator shaft retainer.
5. Tighten the locknut after the adjustment is completed.
