Throttle Cable/Linkage: Service and Repair
REMOVAL1. Remove the accelerator cable from the accelerator pedal and shaft.
2. Remove the accelerator cable from the throttle body.
Accelerator:
3. Squeeze the lock tabs and remove the accelerator cable from the accelerator cable bracket.
4. Squeeze the lock tabs securing the accelerator cable to the bulkhead and remove the accelerator cable.
Accelerator Cable:
1. Position the accelerator cable into the hole in the bulkhead and snap it into place.
2. Install the accelerator cable end on the accelerator cable bracket, and snap it into place.
3. Install the accelerator cable in the throttle body.
4. Install the accelerator cable end on the accelerator pedal and shaft.
5. Adjust the accelerator cable free play and the wide-open throttle position.
