Required Tools and Equipment
The following equipment is required in diagnosing and repairing the Electronic Engine Control (EEC-V) system.Self Test Automatic Readout (STAR) Tester:
Self Test Automatic Readout (STAR) Tester (Rotunda 007-00500, or equivalent)
Vacuum Gauge:
Vacuum Gauge (Rotunda 059-00008, or equivalent)
Tachometer:
Inductive Dwell-Tachometer-Volts Ohms Tester (Rotunda 059-00010, or equivalent)
Breakout Box:
Breakout Box (Rotunda 014-00322, or equivalent)
104 Pin Breakout Box:
104-Pin Breakout Box (Rotunda 014-00950 or equivalent)
Vacuum Pump:
Vacuum Tester (Rotunda 014-R1054, or equivalent)
Digital Volt-Ohmmeter (DVOM):
Digital Multimeter (Rotunda 105-00051, or equivalent)
