Front Seat Belt Buckle
Removal
1. Slide the front seat as far rearward as possible.
2. Remove the front safety belt buckle end anchor bolt.
3. If removing the LH front safety belt buckle end, disconnect the battery ground cable and disconnect the safety belt warning indicator switch.
4. Remove the front safety belt buckle end.
Installation
To install, reverse the removal procedure. Tighten the front safety belt buckle end anchor bolt to 38-78 Nm (28-58 lb-ft).
