Service Procedure
NOTEUSE THIS SERVICE PROCEDURE IF REPLACEMENT OF THE NEW DESIGN MAIN CONTROL COVER AND/OR NEW DESIGN TUBE ASSEMBLY IS REQUIRED.
NOTE
BEFORE INSTALLING NEW VENT TUBE, PURGE ANY OBSTRUCTION FROM THE HOSE LINE USING LOW PRESSURE AIR SUPPLY. HIGH PRESSURE CAN BLOW PAST ANY OBSTRUCTION WITHOUT EVACUATING THE HOSE. WHEN INSTALLING THE HOSE, FOLLOW THE INSTRUCTION SHEET PROCEDURE WITH THE VENT TUBE KIT, ENSURING THE HOSE IS NOT KINKED.
PROBE
1. Fully seat straight end of tube onto brazed fitting on main control cover. Mount clamp securely onto brazed fitting to secure tube assembly (Figure 3).
2. Route tube assembly toward rear of vehicle.
NOTE
BE SURE 90 DEGREE ELBOW IS FACING DOWNWARD.
3. Install tube assembly on air cleaner housing and align white dot with retaining bracket closest to front of vehicle. Insert 90 degree elbow end of tube assembly into air cleaner clamp. Allow approximately 25 mm (1") of free tube (Figure 4).
CONTOUR/MYSTIQUE, COUGAR
2. Route tube assembly upward toward the rear of the battery (Figure 5).
3. Attach clip to battery hold-down bracket bolt (Figure 6).
4. Be sure 90 degree tube end is routed downward (Figure 7).
NOTE
USE SERVICE KITS FOR PREVIOUS DESIGN GROMMET-STYLE VENT ASSEMBLY MAIN CONTROL COVER.
The 1994-1997 2.0L CD4E Probe Remote Vent Kit (F6RZ-7034-BA) consists of the following parts:
^ One (1) Vent Tube - 460 mm (18.1")
^ One (1) Barbed Vent Body
^ One (1) Clamp
^ One (1) White Plastic Clip
^ One (1) Black Steel Clip
^ One (1) Instruction Sheet (I.S. 7142A)
The 1995-1997 Contour/Mystique Remote Vent Kit (F6RZ-7034-AA) consists of the following parts:
^ One (1) Vent Tube - 640 mm (25.2")
^ One (1) Clamp
^ One (1) Instruction Sheet (I.S. 7143A)
