Reverse Clutch
INSPECTION
1. Wipe friction plates clean with a lint-free cloth, then clean all other parts thoroughly with solvent and dry with compressed air.
CAUTION: Clutch plates should not be cleaned with any type of detergent solution or in a vapor degreaser.
2. Inspect clutch plates, pistons and seals, bushings, check ball in drum, band contact area on drum outer surface, and piston bore for damage and excessive wear.
