Fluid Pump: Testing and Inspection
INSPECTION
1. Clean all parts thoroughly in solvent, then dry with compressed air.
2. Inspect oil pump gear teeth, gear bore, crescent, lube passages, and holes.
3. Inspect pump support apply circuit passages and lube passages.
