Engine: Labor Times
Standard HoursManufacturer Warranty HoursSkill LevelNotes
Diagnose/Test
Compression, Test1.40.0BIncludes: R&R Spark Plugs.
Oil Leak, Diagnosis1.00.7C
Replace
Complete Assembly Without Transfer Of Parts
Manual Trans6.64.7BIncludes: Remove Engine & Transaxle As An Assembly. Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
Auto Trans7.35.2BIncludes: Remove Engine & Transaxle As An Assembly. Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
Note
With AC, Add0.50.3B
Complete Assembly With Transfer Of Parts
Manual Trans9.10.0BIncludes: Remove Engine & Transaxle As An Assembly. Transfer Of All Fuel & Electrical Units, Does Not Include Transfer Of Optional Equipment.
Auto Trans9.80.0BIncludes: Remove Engine & Transaxle As An Assembly. Transfer Of All Fuel & Electrical Units, Does Not Include Transfer Of Optional Equipment.
Note
With AC, Add0.50.0B
Long Block
Auto Trans16.88.4BIncludes: R&R Engine & Transfer All Necessary Components Not Supplied With Long Block.
Manual Trans15.87.9BIncludes: R&R Engine & Transfer All Necessary Components Not Supplied With Long Block.
Note
With AC, Add0.50.3B
Short Block
Manual Trans19.79.4AIncludes: Remove Engine & Transaxle As An Assembly And Transfer All Necessary Components.
Auto Trans20.79.9AIncludes: Remove Engine & Transaxle As An Assembly And Transfer All Necessary Components.
Note
With AC, Add0.50.3A
To Grind Valves, Add8.05.7A
Overhaul/Rebuild
Auto Trans34.20.0AIncludes: Remove Engine & Transaxle As An Assembly. Disassemble & Clean Engine, Ridge Ream & Hone Cylinders, Inspect And Replace All Necessary Components, Grind Valves And Tune-Up.
Manual Trans33.60.0AIncludes: Remove Engine & Transaxle As An Assembly. Disassemble & Clean Engine, Ridge Ream & Hone Cylinders, Inspect And Replace All Necessary Components, Grind Valves And Tune-Up.
Note
With AC, Add0.50.0A
