Roof Panel Overcrowned
If the roof panel is overcrowned to the contour of the sliding roof panel (at rear of the sliding roof panel), wind noise or water leak conditions can result.
CAUTION: Excessive overbending could distort the roof panel, requiring costly metal finishing service. This procedure should be used only as a last resort.
Remove the sliding roof panel from the vehicle and carefully overbend the center of the roof panel by applying downward pressure.
