Front
The brake pads are held in the front disc brake caliper anchor plate by two clips. The inboard brake shoe and lining is equipped with a wear indicator. The indicator contacts the front disc brake rotor and makes a squealing noise when the brake pads are worn. This assures that the brake pads will be replaced before any front disc brake rotor damage occurs.
