Backing Plate: Testing and Inspection
1. Inspect the anchor plate rivets. The rivets must be tight and securely peened.2. Inspect the brake shoe and lining contact pads (where the brake shoes and linings rest). Deep grooves in the brake shoe and lining contact pads could restrict brake shoe and lining movement.
If grooves exist, hand sand the brake shoe and lining contact pads.
If the grooves are still present after hand sanding the brake backing plate must be replaced. Any attempt to remove the grooves by grinding may result in improper brake shoe and lining to brake drum contact.
