Brake Line
Double wall steel tubing is used throughout the brake system with the exception of the front brake hoses and rear wheel brake hoses.Always bleed the applicable primary or secondary brake system after primary or secondary brake system component replacement.
When connecting a brake tube flare nut, tighten the brake line flare nut to 13-22 Nm (10-16 ft. lbs.).
