Brake Fluid Reservoir
1. Remove the brake master cylinder.
2. Mount the brake master cylinder in a soft-jawed vise and remove any brake fluid from the brake master cylinder reservoir. Remove the brake master cylinder reservoir screw.
3. Gently pry up on the brake master cylinder reservoir with a small pry bar and remove it from the brake master cylinder.
4. Remove the brake master cylinder reservoir seals from the brake master cylinder.
1. Lubricate the brake master cylinder reservoir seals with clean brake fluid and install them in the brake master cylinder reservoir.
2. Place the brake master cylinder reservoir upside down on a clean work bench and press the brake master cylinder down over the brake master cylinder reservoir.
3. Install the brake master cylinder reservoir screw.
