Electronic Brake Control Module: Service and Repair
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.REMOVAL
NOTE: The anti-lock brake control module is located behind the LH cowl side trim panel.
2. Remove the LH cowl side trim panel.
3. Disconnect the anti-lock brake control module electrical connector.
ABS Control Module:
4. Remove the two anti-lock brake control module nuts and the anti-lock brake control module.
1. To install, reverse the removal procedure. Tighten the anti-lock brake control module nuts to 9-13 Nm (81-113 inch lbs.).
