Technician Safety Information
WARNING: BRAKES CONTAIN ASBESTOS FIBERS. AVOID BREATHING DUST. BREATHING ASBESTOS DUST MAY CAUSE ASBESTOSIS AND CANCER. BREATHING ASBESTOS DUST IS HAZARDOUS TO YOUR HEALTH. DUST AND DIRT PRESENT ON WHEEL BRAKE AND CLUTCH ASSEMBLIES MAY CONTAIN ASBESTOS FIBERS THAT ARE HAZARDOUS TO HEALTH WHEN MADE AIRBORNE BY CLEANING WITH COMPRESSED AIR OR BY DRY BRUSHING.
WHEEL BRAKE ASSEMBLIES AND CLUTCH FACINGS SHOULD BE CLEANED USING A VACUUM CLEANER RECOMMENDED FOR USE WITH ASBESTOS FIBERS SUCH AS ROTUNDA BRAKE/CLUTCH/SERVICE VACUUM 164-R3600 EQUIVALENT. DUST AND DIRT FROM VACUUM SHOULD BE DISPOSED OF IN SUCH A MANNER THAT PREVENT DUST EXPOSURE, SUCH AS SEALED BAGS. THE BAG MUST BE LABELED AS PER OSHA INSTRUCTIONS AND THE TRASH HAULER NOTIFIED AS TO THE BAG'S CONTENTS.
IF A VACUUM SUITABLE FOR ASBESTOS IS NOT AVAILABLE, CLEANING SHOULD BE DONE WET. IF DUST GENERATION IS STILL POSSIBLE, TECHNICIANS SHOULD WEAR GOVERNMENT-APPROVED TOXIC DUST PURIFYING RESPIRATORS. GRINDING OR SANDING ON BRAKE LININGS, PADS, ROTORS, DRUMS OR CLUTCH FACINGS SHOULD BE DONE ONLY WHILE USING PROPERLY EXHAUST-VENTILATED EQUIPMENT. OSHA REQUIRES AREAS WHERE ASBESTOS DUST GENERATION IS POSSIBLE TO BE ISOLATED AND POSTED WITH WARNING SIGNS. ONLY TECHNICIANS CONCERNED WITH PERFORMING BRAKE OR CLUTCH SERVICE SHOULD BE PRESENT IN THE AREA.
LUG NUTS MUST BE RETIGHTENED TO PROPER TORQUE SPECIFICATION AT 800 KM (500 MILES) OF NEW VEHICLE OPERATION. RETIGHTEN TO PROPER TORQUE SPECIFICATION AT 160 KM (100 MILES) AND ALSO AT 800 KM (500 MILES) OF NEW OPERATION. RETIGHTEN TO PROPER TORQUE SPECIFICATIONS AT 800 KM (500 MILES) AFTER ANY WHEEL CHANGE OR ANY OTHER TIME THE LUG NUTS HAVE BEEN LOOSENED. IMPROPERLY TIGHTENED LUG NUTS COULD ALLOW THE WHEEL TO COME OFF WHILE THE VEHICLE IS IN MOTION, CAUSING LOSS OF CONTROL.
