Cruise Control Servo Cable: Service and Repair
1. Disconnect the speed control cable from the accelerator pedal shaft lever.
2. Remove the speed control servo.
3. Detach the speed control cable sealing grommet from the bulkhead.
4. Remove the speed control cable from the vehicle.
1. Position the speed control cable in the engine compartment and insert the accelerator pedal extension end through the bulkhead.
2. Attach the speed control cable sealing grommet to the bulkhead.
3. Connect the speed control cable to the accelerator pedal and shaft lever.
4. Install the speed control servo.
5. Adjust the speed control cable.
