Vehicle Speed Sensor/Transducer - Cruise Control: Service and Repair
2. Remove the air cleaner assembly.
3. Disconnect the electrical connector from the Vehicle Speed Sensor (VSS).
4. Remove the VSS bolt.
5. Remove the VSS .
6. Inspect the VSS O-rings for nicks and cuts.
- Replace if necessary.
