Coolant Reservoir: Service and Repair
1. Drain the radiator to a level below the outlet connection for the radiator coolant recovery reservoir hose and then close the radiator draincock.
3. Remove the five left front fender splash shield bolts and remove the front fender splash shield.
4. Disconnect the radiator coolant recovery reservoir hose from the radiator coolant recovery reservoir.
5. Remove the two bolts and lower the reservoir neck through the sheet metal opening.
^ Tighten the front fender splash shield bolts to 8-10 Nm (71-88 inch lbs.).
^ Refill the cooling system.
