Crankshaft Gear/Sprocket: Service and Repair
1. Remove the timing belt.
2. Use Crankshaft Damper Remover T74P-6316-A to remove the crankshaft sprocket.
3. Remove the crankshaft sprocket key.
1. Install the crankshaft sprocket key and crankshaft sprocket.
2. Install the timing belt.
