Crankshaft: Service and Repair
Dress minor imperfections such as scores, nicks or burrs with an oil stone. If the journals are severely marred or exceed the service limit, they should be refinished to size for the next undersize crankshaft main bearing. If the journals will not clean up to maximum undersize bearing available, replace the crankshaft.
Always reproduce the same journal shoulder radius that existed originally. Too small a radius will result in fatigue failure of the crankshaft. Too large a radius will result in bearing failure due to radius ride of the crankshaft main bearing.
After refinishing the journals, chamfer the oil holes. Polish the journal with a No. 500 grit polishing cloth and engine oil (crocus cloth may also be used as a polishing agent) to obtain a smooth finish.
