Engine Oil Dip Stick - Dip Stick Tube: Service and Repair
REMOVAL1. Remove the oil level dipstick.
2. Remove the oil level indicator tube bolt, and then pull the oil level indicator tube from the engine. Discard the O-ring.
1. Install the oil level indicator tube with a new O-ring. Tighten the oil level indicator tube bolt to 8-10 Nm (71-88 inch lbs.).
2. Install the oil level dipstick.
