A/C System - Manual
R-134a REFRIGERANT SYSTEMWARNING
- AVOID BREATHING A/C REFRIGERANT AND LUBRICANT VAPOR OR MIST. IF ACCIDENTAL SYSTEM DISCHARGE OCCURS VENTILATE THE WORK AREA BEFORE RESUMING SERVICE.
- LIQUID HFC-134A, AT NORMAL ATMOSPHERIC PRESSURES AND TEMPERATURES, EVAPORATES SO QUICKLY THAT IT HAS THE TENDENCY TO FREEZE ANYTHING IT CONTACTS. EXTREME CARE MUST BE TAKEN TO PREVENT ANY LIQUID FROM COMING IN CONTACT WITH THE SKIN AND ESPECIALLY THE EYES.
- WEAR IMPERVIOUS GLOVES AND SAFETY GOGGLES AT ALL TIMES WHEN HANDLING LIQUID REFRIGERANT. SHOULD ANY LIQUID REFRIGERANT GET INTO THE EYES OR ON THE SKIN, IMMEDIATELY FLUSH EYES AND SKIN WITH PLENTY OF WATER FOR AT LEAST 15 MINUTES. REMOVE THE CONTAMINATED CLOTHING AND SHOES. CALL A PHYSICIAN.
- REFRIGERANT HFC-134A IS ALWAYS UNDER PRESSURE. BECAUSE THE SYSTEM IS TIGHTLY SEALED, HEAT APPLIED TO ANY PART COULD CAUSE THIS PRESSURE TO BUILD UP EXCESSIVELY. TO AVOID A DANGEROUS EXPLOSION, KEEP AWAY FROM OPEN FLAMES, GLOWING METAL SURFACES, BLOW TORCH, STEAM CLEANING AND WELDING. HFC-134A CAN BE DECOMPOSED AT HIGH TEMPERATURE.
CAUTION
- Using R-12 components, refrigerant, or refrigerant oil on an R-134a system will cause damage to the A/C system. Do not replace components, refrigerant, or refrigerant oil from an R-134a system with components, refrigerant, or refrigerant oil for an R-12 system or vice versa. R-12 and R-134a components are not interchangeable. Mixing components from these two types of systems will cause component failure and damage to the A/C system.
- The refrigerant used in this refrigerant system is HFC-134a (Tetrafluoroethane) which is a hydrofluorocarbon refrigerant. HFC-134a, also known as R-134a is non-corrosive, non-explosive, non-flammable and has a slight ethereal type odor. HFC-134a is heavier than air. Although it is classified as a safe refrigerant, certain precautions must be observed to protect the parts Involved and the person working on the unit.
- Use only HFC-134a refrigerant. Due to environmental concerns, when the air conditioning system is drained, the refrigerant must be collected using refrigerant recovery/recycling equipment meeting SAE J1990 and J2210 standards. HFC-134a must never be removed without the appropriate equipment or released into the atmosphere. Use of a recovery machine dedicated for R-134a is necessary to reduce the possibility of oil and refrigerant incompatibility concerns.
- Ensure that containers are never heated to over 52°C (125°F). Containers should be stored and installed in accordance with all state and local ordinances.
- When admitting HFC-134a into the refrigerant system keep the tank in an upright position. If the tank is on its side or upside down, liquid HFC-134a will enter the system and may damage the compressor.
- Refrigerant HFC-134a should not be mixed with air for leak testing or used with air for any purpose above atmospheric pressure. HFC-134a is combustible when mixed with high concentrations of air and high pressure.
A/C-HEATER SYSTEM, MANUAL
The air conditioning system consists of:
- A/C compressor.
- A/C condenser core.
- A/C evaporator core orifice.
- A/C evaporator core.
- Suction accumulator/drier.
- A/C cycling switch.
- A/C pressure cut-off switch.
- Climate control assembly.
- Refrigerant lines.
This system is designed to cycle the A/C compressor on and off to maintain desired cooling and prevent the A/C evaporator core from freezing. Passenger compartment comfort is maintained by the mix of cooled and heated air as controlled by the temperature control on the climate control assembly.
System operation is controlled by the A/C evaporator core orifice and the A/C cycling switch.
