Electrical System
The electrical system in the climate control system uses the following components:
- A/C clutch field coil.
- A/C clutch control relay, located in the main fuse junction panel.
- Powertrain Control Module (PCM) relay.
- Thermal protection switch.
- Powertrain control module.
- A/C pressure cut-off switch.
- A/C condenser cooling fan.
- [1][2]Blower motor relay #1.
- [1][2]Blower motor relay #2.
- A/C blower motor resistor.
- Blower motor.
- Blower motor switch.
- Climate control assembly.
- A/C cycling switch.
- High condenser fan relay.
- Low condenser fan relay.
- High Fan Control relay.
- Low Fan Control relay.
