Liquid Lines
SPECIAL SERVICE TOOL(S) REQUIREDDescription Model
Spring Lock Coupling Disconnect Tool (3/8 in.) T81P-19623-G1
Spring Lock Coupling Disconnect Tool (1/2 in.) T81P-19623-G2
Spring Lock Coupling Disconnect Tool (5/8 in.) T81P-19623-C
Spring Lock Coupling Disconnect Tool (1/2 in.) T81P-19623-A
NOTE: Whenever a refrigerant line is replaced, it will be necessary to replace the suction accumulator/drier.
1. Discharge the A/C system into a proper recovery system. Discharging and Recovery
2. Use an appropriate spring lock coupling disconnect tool to disconnect the condenser to evaporator spring lock coupling from the A/C evaporator core outlet hardline (near the dash panel).
3. Use an appropriate spring lock coupling disconnect tool to disconnect the condenser to evaporator tube spring lock coupling from the liquid line extension.
4. Remove the condenser to evaporator tube hold down bracket bolt.
5. Remove the condenser to evaporator tube.
1. Install the condenser to evaporator tube.
2. Using new O-rings lubricated with clean Motorcraft Refrigerant Oil YN-12b or equivalent meeting Ford specification WSH-M1C231-B, connect both spring lock couplings.
3. Leak test, evacuate and recharge the A/C system. Service and Repair
