Brake Warning Indicator: Description and Operation
Brake SystemThe brake warning indicator has a dual function. It illuminates when the parking brake control is applied or when a low brake fluid condition exists in the brake master cylinder reservoir.
Anti-Lock Brakes
The anti-lock warning indicator illuminates if the anti-lock brake system fails. The warning indicator will flash when the self test is activated.
