Instrument Cluster - Housing
2. Loosen the hood release handle nut.
3. Remove the instrument panel lower side panel screw.
4. Remove the LH foot lamp from the instrument panel lower side panel by turning the LH foot lamp one-quarter turn counterclockwise and pulling it straight out.
5. Remove the instrument panel lower side panel.
Steering Wheel Removed For Clarity:
6. Remove the five instrument cluster housing screws.
7. Disconnect the light switch rheostat resistor electrical connector.
8. Remove the instrument cluster housing.
