Instrument Cluster - Printed Circuit
REMOVAL1. Remove the instrument cluster.
2. Push in the lock tabs and remove the instrument cluster main lens from the instrument cluster back plate.
3. Remove the two fuel indicator module plastic cover screws.
4. Flip the lower right corner of the plastic cover up and disconnect the fuel indicator module electrical connector.
5. Remove the fuel indicator module.
6. Remove the 18 miniature bulbs from the instrument cluster back plate by turning the miniature bulbs one-quarter turn counterclockwise and pulling straight out.
7. Remove the 21 instrument cluster printed circuit screws.
