Volt Meter Gauge: Description and Operation
The battery voltage gauge is identified by a battery symbol on the gauge face and is located to the right of the tachometer and below the oil pressure gauge. The battery voltage gauge indicates battery voltages between the battery voltage gauge operating range of 9-17 volts. The battery voltage gauge is standard on all models, and no battery warning indicator is available.
