Backup Light Bulb: Service and Repair
REMOVAL AND INSTALLATIONAll the exterior miniature bulbs can be removed using this procedure:
a. Remove the lamp if necessary.
Press In and Rotate To Remove:
Pull Straight Out To Remove:
b. Remove the miniature bulb from the lamp socket. This can be done one of two ways depending on the type of miniature bulb used for each application. The illustrations shows the removal of miniature bulb.
