Flow of Diagnosis
1. Verify the customer concern by operating the backup lamps.
2. Visually inspect the components of the backup lamp system.
Mechanical
- Transmission range switch/sensor.
Electrical
- Blown fuse:
+ 15 A METER.
- Damaged backup lamp miniature bulb.
- Damaged wiring harness.
