1. Verify the customer concern by operating the stoplamp system.
2. Visually inspect the components of the stoplamp system.
Mechanical
- Brake On/Off (BOO) switch.
Electrical
- Blown fuse:
+ 20 A STOP.
- Damaged stoplamp miniature bulb.
- Damaged wiring harness.
