Brake Light Switch: Service and Repair
1. Remove the lower steering column shroud.
2. Disconnect the Brake On/Off (BOO) switch electrical connector.
3. Remove the BOO switch by rotating it 90 degrees and pulling it out from the brake pedal.
NOTE: To be sure that the BOO switch is securely installed, push the BOO switch in until it bottoms out against the brake pedal.
