Center Mounted Brake Lamp: Service and Repair
REMOVAL1. Remove the rear package tray lifting strap from the liftgate side trim mouldings.
2. Carefully pull the liftgate side trim mouldings away from the liftgate to disengage the clips.
3. Remove the two liftgate side trim mouldings.
4. Remove the liftgate upper trim moulding clip and pull the liftgate upper trim moulding loose from the liftgate and remove it.
5. Remove the three rear hi-mount lamp housing bolts.
6. Disconnect the rear hi-mount lamp electrical connector and remove the rear hi-mount lamp housing.
To install reverse the removal procedure.
