Flow of Diagnosis
1. Verify customer concern by operating courtesy lamps.
2. Visually inspect the components of the courtesy lamp system.
Mechanical
- Improperly adjusted door.
- Misaligned liftgate.
- Damaged liftgate latch.
Electrical
- Blown fuse(s):
+ 15 A ROOM.
+ 15 A TAIL.
- Damaged wiring harness
- Loose or corroded connections
- Damaged lamp(s).
- Damaged switch(es).
- Damaged Central Processing Unit (CPU).
3. If fault is not visually evident, determine the symptom and proceed to the symptom chart. Symptom Related Diagnostic Procedures
