Flow of Diagnosis
1. Verify the customer concern by operating the daytime running lamps.
2. Visually inspect the components of the Daytime Running Lamp (DRL) system:
Electrical
- Blown fuse(s):
+ 30 A HEAD.
+ 15 A AIR COND.
- Damaged fog lamp bulb(s).
- Damaged wiring harness.
