Dome Lamp Switch: Testing and Inspection
NOTE: This component test requires the map lamp miniature bulbs and the dome lamp miniature bulb to be good.
1. Key OFF.
2. Disconnect the roof console C900.
3. Measure the continuity between the terminals of the roof console C900 as indicated in the chart.
4. If the roof console switch is OK, return to the Pinpoint Tests. Pinpoint Tests
5. Otherwise, replace the roof console.
